Version: Windchill 13.0
Use Case: I want to communicate with Windchill via REST/OData and Bearer Authorization from a Third Party Application
Description:
I have successfully configured Windchill on OIDC and JWT with Microsoft Entra using this documentation: https://support.ptc.com/help/windchill/r13.1.0.0/de/index.html#page/Windchill_Help_Center/WCAdvDeployGuide/WCAdvDepAuth_OIDC.html Is it now possible for me to communicate with Windchill from another application using JWT/Access tokens with Bearer Auth? I have tried various approaches but have not been able to do so.
Maybe I am missing some Configurations or it isn't possible
Hi @dullnigAlex
Thank you for your question.
Best regards,
Hi @dullnigAlex ,
You have to configure OAuth delegated Authorization to use JWT Tokens for accessing Windchill.
Once it's done you can pass JWT token in Authorization header with value "Bearer <JWT Token>" and the URL should have oauth like below
GET https://<host>:<port>/Windchill/oauth/servlet/odata/ProdMgmt/Parts
Rajesh D
