Windchill Odata rest service : stream primary content file
HK_8689240
3-Newcomer
Version: Windchill 12.1
Use Case: am trying to retrieve the primary content of WTDocument, Am trying to use "type":"Edm.Stream", but insuccessful. Could you please suggest the right approach
Description:
download primary content using Odata Rest Service
Hi @HK_8689240
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Hello Joe,
The below return type stream the file, OOTB API return only the URL
"new Property(EdmPrimitiveTypeKind.Stream.toString(), zipFileName + ZIP_EXT, ValueType.PRIMITIVE, IOUtils.toBufferedInputStream(fis))" for "Edm.Stream" type
