I have developed a custom action menu on WTPart (a default object in Windchill), but for some reason, the same action menu is appearing on its child objects as well.
I would like to know how I can limit the display of this custom action menu only to the main WTPart object and not its children.
Shrikant Bhosle
I employed custom-actionModel.XML configuration instead of a UI validator for this particular task.
According to the PTC guide, it is also possible to achieve this using XML file configuration instead of a UI validator.
Please correct me if I have misunderstood.
Ref:
<supportedTypes>
<type value="wt.part.WTPart" applyToDescendants="false"/>
</supportedTypes>
Link:
https://support.ptc.com/help/wnc/r12.0.2.0/en/index.html#page/Windchill_Help_Center%2FWCCG_UICust_AddActionsHook_WCClientArchAction_AddingValidation.html
Best Regards,
Shrikant Bhosle
Hi @SB_10566278
You can create own validator that checks the subtype information and base on this info you show or not show the action
CS52551 - How to write UI Validator
Community - How to create and register an tab Validator in Windchill
PetrH
Ref:
<supportedTypes>
</supportedTypes>
Link:
Best Regards,
Shrikant Bhosle
Hi @SB_10566278
I'm not sure if you can define the subtype string
It is generally used for root (parent)types.
So WTPart, Document, CADDocument, Operation atc.
also you can try to use specific type definition for subtype like "wt.part.WTPart|com.ptc.MYSubtype"
But I preferer to use the validator.
PetrH
