Hello all,
I'm having a workflow issue and hope someone can help. We have a process whose workflow requires approvals. Each approvers is given 2 options (votes), Complete or Rework. If all approvers vote "Complete", the workflow moves along to the next activity (coordinator approve and release), as expected. However, if any one approvers votes "Rework", the process assigns a Rework task (expected) but also moves forward to the next activity. This causes an issue for the person assigned the Rework task as they can't update or edit the object because it is undergoing a review process. (See attachment for error message) This also means you can't change the state even from an admin account either for the same reason. Any ideas as to what is happening?
Thanks in advance for any suggestions and / or ideas.
David
Can you provide a screenshot of the workflow ?
Hi Olivier,
I think Kaushik's answer below got me going in the right direction. I appreciate your reply. If you would still like to see the workflow, I'l screenshot and attach it.
Best,
David
Hi David,
I am guessing that you are using 'All' to ensure that every approver provides a vote before you can move forward.
So, if one of them cast vote as 'Rework' system is triggering 'Rework' task and if another approver select 'Approve' the system is triggering the next task for 'Approver'. The system is behaving as expected.
Use the tally expression so that workflow always goes to 'Rework' if any one of the approvers selects 'Rework'.
This is a classic example of using tally.
<WC_URL>/Windchill-WHC/index.jspx?id=WFTranSampleCompleteTask&action=show
PTC Support is down for maintenance activity. So, unable to post a link.
If you are in Windchill 11, then go to help center and search for a page named 'Complete Task Transition'. There's a good example.
Kaushik
Hey Kaushik,
I'm currently running 10.2 but I took some of the info you referenced and was able to get it working. We actually ended up creating a new LC sate and using some of the coding and it seems to be working.
Thank you for the help!
Best,
David
You are welcome, David.
Happy to help.
Since you are using windchill 10.2 environment, there's another way to counter the problem as mentioned in following document.
Reject on 1st Reject Vote.pptx
Kaushik
Hi All,
Well Answer to this for WC 11 is 'Complete Task Transition' which Kaushik as described above.
But for 10.2 or earlier you need to use Sync robot and terminate the open activities in Workflow to achieve this. you can refer Articles:
Rahul
