can you please explain the detailed steps to registered JSP files for attached document ?
WT_010219
Hello
can you please explain the detailed steps to registered JSP files ?
I registered Datautility, added property file location into  "TgsPropertyHelper". but not getting idea how to register the "createDocumentSetTypeAndAttributesWizStep.jsp" and "loadStateNames.jsp" JSP files ?
please find attached file for reference
6 REPLIES 6
HelesicPetr
(To:WT_010219)
Hi @WT_010219
Please download a Customization guide and search for custom/wtCustomActions.xml where the actions are defined
https://www.ptc.com/en/support/article/CS60345
page around
1616 Add Custom Commands
or help center
Server Side Customization
PetrH
Thanks for your reply @HelesicPetr
My question was in reference to below attached file.
HelesicPetr
(To:WT_010219)
Hi @WT_010219
You don't need to register jsp pages, Just store them to the codebase/netmarkets folder to respect your package and use them in browser.
In some cases the location is in web-inf folder...
PS> if you share your problem, and describe some more details of your work with errors it could help to understand your issue,
PetrH
I kept them at D:\PTC\Windchill\codebase\netmarkets\jsp\customjsp but nothing happen when tested the implementation.
HelesicPetr
(To:WT_010219)
Hi @WT_010219
The point is how do you use them in your application(cusomization)?
What do you expect that should happen?
DataUtility is just for showing things in the document there is just ComboBox.
It is not connected to any jsp
so what do you need?
Describe it.
PS: try to study the customization help .how to create Wizard - how the jsp pages are used in the wizard and so on.
PetrH
Hello @WT_010219
It looks like you have some responses from a community member. Please reply to the questions from "HelesicPetr".
Or, if any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
