how to get creo view URL for a representation of CAD Document?
gmydoor-2
HI all,
Using below API  I am able to get representations for EPM document. Is there any API to get creo view URL of a representation?
VisualizationHelper visualizationHelper = new VisualizationHelper();
QueryResult epmReps = visualizationHelper.getRepresentations(epm);
HelesicPetr
(To:gmydoor-2)
Hi @gmydoor-2
The result of getRepresentations should contain files for Creo view.
If you need to download them then use
try
	Representation defaultRep = RepresentationHelper.service.getDefaultRepresentation(cadDoc);
	Vector<ApplicationData> vectorOfAppData = ContentHelper.getContentListAll(defaultRep);
	Iterator<ApplicationData> appIter = vectorOfAppData.iterator();
	while (appIter.hasNext())
		ApplicationData syAppData = appIter.next();
		ContentHolder holder = ContentHelper.service.getContents(defaultRep);
		final URL viewContentURL = WVSContentHelper.getViewContentURL(syAppData, holder);
		final URL downloadURL = WVSContentHelper.getDownloadURL(syAppData, holder);
} catch (WTException | PropertyVetoException e)
	e.printStackTrace();
PetrH
HelesicPetr
(To:gmydoor-2)
Hi @gmydoor-2
try
PetrH
Thanks for the response. @HelesicPetr
Hi @HelesicPetr
Is there an API to generate the creoview URL(creoview://?wcparams=...) that launches the Creo View application for a given list of part(s) with the version?
Note : There is this OOTB REST endpoint(../Windchill/servlet/rest/visualization/objects/) that does it with OID and version, just curious if it can be done via API and also for a list of parts.
HelesicPetr
(To:MV_10441462)
Hi @MV_10441462
If you check the open representation link, then you can see that the API has to exist
PetrH
Here's some code I wrote recently that returns a URL which opens the default representation of a given object in CreoView...
public static String getCreoViewURL(WTObject object) {
		System.out.println("==> getCreoViewURL");
		String url = "";
		try {
			VisualizationHelper visualizationHelper = VisualizationHelper.newVisualizationHelper();
			QueryResult representations = visualizationHelper.getRepresentations(object);
			if (representations != null) {
				while (representations.hasMoreElements()) {
					Representation representation = (Representation) representations.nextElement();
					if (representation.isDefaultRepresentation()) {
						ContentHolder holder = ContentHelper.service.getContents(representation);
						String downloadURL = WVSContentHelper.getDownloadURLForType(holder, ContentRoleType.PRODUCT_VIEW_ED);
						url = "'/Windchill/wtcore/jsp/wvs/edrview.jsp?url=" + downloadURL + "&objref=OR%3A" + holder.toString() + "'";
		} catch (Exception e) {
			System.out.println(e.getMessage());
		System.out.println("<== getCreoViewURL");
		return url;
