how to get data from OData from within JSP
rleir
Team
Is it possible to GET OData data from within JSP code? It would GET from the local Windchill (localhost).
Do I have an authentication problem?
HelesicPetr
(To:rleir)
rleir
(To:HelesicPetr)
Petr:
As for authentication, I can see how in the JSP to get the username. Is the usr:pwd needed in the OData URL when the call is within Windchill?
cheers -- Rick
HelesicPetr
(To:rleir)
Usually you need login with a password to open new session.
I would say if you communicate with windchill you need to authenticate
PetrH
rleir
(To:HelesicPetr)
Petr:
But the user is already authenticated, for example
domain.com/Windchill/wtcore/jsp/test/dynAuth.jsp
or domain.com/Windchill/app/#wtcore/jsp/test/dynAuth.jsp
The user will not want to enter her password again. I can get the username from "<%=request.getRemoteUser()%>" and insert it in the WRS URL, but  not the password.
No, scrub this question because there could not be a way to get the password here. It would be a major security problem.
