how to update the attribute value existing WTObject in Customization
AR_9920456
HelesicPetr
(To:AR_9920456)
Hi @AR_9920456
It depends what attribute you are planning to update
but I would recommend you to use the Knowledge Base, the fourth article shows you how to do so.
https://www.ptc.com/en/support/search/#q=API%20how%20to%20update%20attribute
Use the PersistableAdapter  adapter.
PS> your question has been answered several times
How-to-update-IBA-value-without-object-checkout-and-checkin
PetrH
HelesicPetr
(To:AR_9920456)
Hi @AR_9920456
PetrH
