Is there a api which lets us add multiple users to single role.
Hi @SB_10904295
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hi @SB_10904295
Try to check following class and method.
https://www.ptc.com/en/support/article/CS138084
I guess that you have to use while/for loop to add more users.
or you can try following method but I've never use it.
addRolePrincipalMap(HashMap var1, WTRoleHolder2 var2)
PetrH
I used this method and it works.
team.addPrincipals(HashMap map);
Hi @SB_10904295
Can you explain what values do you use in the HasMap input please? it would be useful for others.
Thank you
PetrH
