post publish 2D epm to jpg
rvanveerdeghem
11-Garnet
I found this article https://www.ptc.com/en/support/article?n=CS251134 but I can't read everything, because we have some problems with maintenance. We already create PDF, DXF for a drawing in windchill, but it would be great to also have a high resolution JPG. According to the given article, it should be possible, but I can't find how it's done.
Does somebody know, what the steps are to get a jpg?
Thanks in advance
What you need is in the article
    The provided sample WVS Afterloader Hook Method will enable you to create a high resolution JPG image as Additional File Type in Representation
    The Afterloader hook method starts as a post publish job after WVS completes publishing of a new representation
 EDIT: You need to be under maintenance to see the resolution of article
2 REPLIES 2
Thanks Vincent for your awnser. I can open the article again since our maintenance problem is solved.
