Version: Windchill 13.0
Use Case: I am trying to change the initial value of the "Default Trace Code" attribute from "Untraced" to "Serial Number".
Description:
It seems this cannot be done in "Type and Attribute Management". Can anybody advise how this can be achieved?
It seems a partial workaround has been detailed in this article - https://www.ptc.com/en/support/article/CS48279?source=search
It's not clear on how you can apply a "Default Trace Code" initial value to one part type and a different initial value to a different part type. It seems the article doesn't explain how to achieve this.
