"New CAPA Request " is not working on nonconformance
RS_10128209
I have changed in CAPA oir , Im passing attribute value on CAPA name while creating new CAPA but that IBA is not present in Nonconfomance so how can I create CAPA?
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Arg>CAPA-</Arg>
<Attr id="ext.xyz.LOCATION"/>
<Arg>-</Arg>
    <Arg>{GEN:wt.enterprise.SequenceGenerator:CAPAREQUESTID_seq:10:0}</Arg>
                </AttrValue>
HelesicPetr
(To:RS_10128209)
Hi @RS_10128209
The IBA should be presented on the new CAPA object. . .
if it is not there, then you can not use this IBA in the OIR or you have to create the IBA on the correct soft type object. CAPARequest...
PetrH
