Hi @arongoni
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
What is a good question?
Thank you for your participation and please let me know if you need further assistance!
Best regards,
i have everything
server address
port
username
password
recipients are internal clients
i created the connector on microsoft exchange(sap and veeam and other programs work)
i need to reconfigure site.xconf as we migrated from google to M365.
so i need a person who can modify my site.xconf so that the system sends emails.
That person who can modify your site.xconf is you or your admin. Modifications are done using xconfmanager:
https://www.ptc.com/en/support/article/CS94147?source=search
To update mail settings, here is the instructions:
https://www.ptc.com/en/support/article/CS46949?source=search
Specific M365 related:
https://www.ptc.com/en/support/article/CS288408?source=search
https://www.ptc.com/en/support/article/CS302525?source=search
https://www.ptc.com/en/support/article/CS365418?source=search
A word to the wise, the trusted certificate you create and import expires after a period of time. From what I’ve seen I’d say two or three months.
To make life easier I wrote a batch file that will create and import a new certificate. The admin loves it.
Also, you need to hardcode the 0ffice 365 from email address into the IE task SendMail.xml.
This needs to be done in the Send-Mail
webject in that SendMail IE task.
Finally, the SendMail IE task does get overwritten when applying a new CSP, so you have to remember to go back and edit the webject in that task after upgrading to new CSP.
A bit of a pain I know but if you follow these tips you should be Ok.
If you need any help contact me at windchill.developer@yahoo.com
David
Are you talking about delegation? This is done in the user's personal calendar. If you are talking about relaying mail to a mail server, depends on your current setup and OS. What OS are you using and what mail host?
Pdmlink 12.002 on Microsoft server 2019
mail server M365
