实际业务中,常出现,1个元器件 在部分的产品中,可以被另外一个元件替代。 目前只能用特定替代关系进行管理。
当因用于替代的元器件因价格、质量或停产等等问题,需用删除,并换另外一个元器件来替代时,非常难于维护。
例如某个特定替代关系,适用于1个系列的100个产品,需修改100个产品结构。效率太低。
非常期待,能在更改任务中增加批量修改特定替代关系的功能,与批量更改产品结构的数量等功能类似。
"Actual business, often, a component in some of the products, can be another element instead. Can only be managed by a specific substitutes.
When used to replace components due because of price, quality or discontinued and so on, need to remove and replace a component for another, very difficult to maintain.
For example, a specific substitutes for a series of 100 products, you need to modify 100 product structure. Inefficiency.
Really looking forward to increase the bulk in the task to modify the function to change the relationship between specific alternatives, and change the number of batches of product structure similar functions."
