Please create a separate field / attribute for the Change Notice TEMPLATE NAME.
At the moment the Change Notice name itself (attribute "name") is also used as change notice "template name".
Because of that a new change notice template cannot be created with an empty or prefilled/pre-defined name/explanation...
To have a separate field for the template name would help here, so that the change notice name attribute can be used different to the template name.
