Currently, in Windchill 11 M030, there is a progress bar when uploading CAD from Creo, but it repeats itself four times, each time slower than the last, and each one called "Uploading". When a progress bar reaching 100% does not complete the process, the progress bar becomes mostly useless and makes you wonder what data it is using.
The Idea: Consolidate the upload progress bars into one which accurately represents the progress, displays the upload rate, size, and estimated time remaining, and reaches 100% only when the process is actually done (so you're not staring at "100% complete" for 2 minutes while it finishes).
