Ability to add PartsLink classification attributes in any table views
When using Partslink, we are able to define different Classification NameSpace and/or different Classification trees with specific attributes at nodes level.
 But it is impossible to display these attributes in the configurable table views of Windchill.  Notably PSB , MAPSB, CAD2Part compare,Advanced Search Result,  folders, collectors, Change impacted/resulting ,  etc ...
Except the Node/Binding attribute ...
1 Comment
Garnet
Gregory,
can you specify how this should look like since worst case each object could have a different attribute set which makes usability a nightmare.
I like the idea in general and there are definitely some attributes which are on the main nodes and therefore on almost every object.
Oliver
