Ability to add/remove Target Objects from Promotion Request, after it is submitted
I would like to raise a request for enhancement on the below mentioned functionality. I would see this is very much needed for avoiding extra work of cancelling existing PR and creating a new PR, instead of editing the already created one.
- Windchill OOTB should provide the ability to edit the Promotion Request after it is submitted, to add/remove the Target Objects. Edit access can be controlled through the ACLs, so it is not an issue to provide this functionality.
It happens many a times that the designer/approver decide to add/remove some objects to the PR in the middle of it's approval. Currently there is no way to edit the PR once it is submitted, and without this functionality user needs to re-create the PR to make any changes to the Target Objects.
Thanks & Best Regards,
Mahesh KL
Changing this to duplicate.  Please follow up with this idea:
3 Comments
Participant
Yes, it would be good to find an answer for this problem.
Alexandrite
As of 11.0 M030 Edit for Promotion Requests is available - we are now using.
Note: The OTB Promotion Request approval workflow template does not have a "Rework" state and we added this, along with a second "set objects to back to lock state" transition in the rework loop.  Have to do a few things to really get Edits for PR's to be fully functional.
Community Manager
Status changed to: Archived
