Need ability to change the height of the Promotion Comments text box in Windchill PDMLink.
1. At the user end you cannot change the height or width of the Comments box.
2. The height is locked with a hard codded value of 3 as per PTC and cannot be configured.
3. Refer to CS281146 https://www.ptc.com/en/support/article?n=CS281146&language=en&posno=2&q=promotion%20comments&source=...
Our users are asking if the height can be adjusted, as we do have use cases where users create multiple documents and the height is occupying real estate on screen.
