Ability to control "Export List to File" function
Some of our customer have requested a same request to control the "Export List to File" function.
From the security perspectice, some users/group should be disallowed this function.
If this can be controled via ACL or preference, that would be useful.
6 Comments
OliverDroop
You can check the profiles even I believe that this is not there OOTB.
You can always customize and add this action to the profiles or use a custom action validator
JeffZemsky
There is Profile support for Export Importable Spreadsheet (as well as Import Spreadsheet today).  While not the entire list it does give you control over this function.
tseki
Thanks Jeff.
I have tried to set Profile, and restrict "Export Importable Spreadsheet".
Actually the user who is assigned this profile, does not have an option to "Export Importable Spreadsheet", but still be able to export to other formats.
Is there anything I missed?
JeffZemsky
Tsutomu Seki‌ - that is correct.  This is the only Export to that we controlled via profile today.
tseki
Thank you Jeff.
So this request is still "not implemented function" and open request.
I've already seen at least 3 Japanese customers asked the same.
olivierlp
Community Manager
Status changed to: Archived
