Ensure the consistency & quality of a BOM by defining a mandated “Function” for each assembly / component link.
No OOTB solution / Configuration & Customization
•Soft typing of WTPart Usage link
•Add an attribute of type FUNCTION
•This attribute is calculated dynamically based on the father & son relationship
•FUNCTION is used to control the BOM quality (each link must have an authorized function)
•EXAMPLE for a given SCREW:
–FUNCTION 1 : “Screw of the bottom part of a watch” (vis de fond)
–FUNCTION 2: “Screw of the box” (vis de boite)
