We would like to have the ability to make it possible to edit attributes during Check In operation.
Now you have to first select the objects in workspace and then go to Edit > Attributes in order edit the attributes.
After that you will select all the same files again and check them in.
Being able to edit the attributes during Check In will reduce the steps needed.
