1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Industry: OEM Food Production Equipment
Role: Mechanical Engineer
Stakeholders: Customers, Management, Manufacturing
2. What version of Windchill are you currently running?
11.1 M020-CPO24
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Save-As a .dwg without including Attachments. Give the option to not include Attachments when doing a Save-As, either at time of save as, or as a Windchill Preference, or as a Site/Org Level Setting.
4. What is the use case for your organization?
We attach DXFs to our to some of our parts for manufacturing to use. When Engineering does a Save-As on a drawing the attached DXF is saved along with the Save-As. Engineering has to manually delete that attachment, else there is an incorrect DXF attached to a drawing, which opens the opportunity for manufacturing to make the wrong part.
pre save-as:
save-as:
post save-as:
5. What business value would your suggestion represent for your organization?
more efficient Engineering, less error in manufacturing.
