Hello
I would like to be able to remove the function "Check In All-in-One CATPart" from the contextual menu in CATIA because this function doesn't work as we wish.
The other solution is to make this function work as we would like by using the links instead of the name to identify the older iteration of the All-in-One CATPart !
