In the web version of the software, applied filter settings are saved, so any filters still applied when a system is closed will still be in effect the next time the system is opened.
A similar function would be useful also in the desktop version of Windchill Quality Solutions.
See also Article CS206429: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS206429
