In a WTPart BOM using several WTPart sub-type with different attribute list we should be able to search for all WTPart that have a component with a specific value.
Example 1 :
The clock BOM contains a dial and two hands. Clock, Dial and Hand are WTPart sub-types. The types Dial and Hand have the attribute "Luminescent material".
We want to search for all clocks that have a component where "Luminescent material" is Tritium.
We want to have the result ready in standard search result.
Example 2 :
We want to search for all WTPart connected to a EPMDocument where the number contains *_1234_*.
Note: This topic can be solved using calculated attribute for specific and known cases. But it's impossible to generalize it to all sub-type, all attributes and all relations.
