When a company deals with both imperial and metric components, there is no choice to have 2 reusable attributes for the same dimension: one in metric and the other in imperial to get the value "user-readable".
E.g: the length of a screw in millimeters or inches.
Having 2 IBAs makes searches, classification browsing, or table displays less efficient.
The ability to set the measurement system for an object or even for an attribute of an object would be much better.
