When using Change Management and effectivities, effectivities are set to resulting WTParts of the Change Request (resulting datas of the Change Activities),
But these effectivities are "pending" until the Change request si resolved (and the underneath workflow concretely apply the effectivities on WTParts)
So there's no way to filter and visualize the "resulting" WTPart BOM (compare BOM, open in creo view), before releasing the change request.
For example, compare the "lot 1" product structure, with the "future/planned" lot 2 product structure. Notably to review changes made between the 2 lots ...
Ability to use the "Change Management pending effectivities" in the Configuration Specification Filter. To be able to view the "resulting" WTPArt BOM.
Or abilty to use Change Request objects in the Config Spec Filter.
