Access control - Attribute modification only while checkout
In order to simplify some processes and remove some customization we want to be able to grant only attribute modification access to users/group/role. The user shouldn't be able to update structure or documents associations.
Uses cases :
We has to develop a wizard that allow Customer Service administrator to modify some attribute and add WTDocument on Design view because we don't want that they modify BOM.
In a same way it should be great to grant access only to :
BOM modification
WTDocument association (Reference)
WTDocument association (Described by)
EPMDocument association
2 Comments
BjoernRueegg
It would make it so much easier if the fineness of the ACL would be bigger. It also would be great even to set permission to a single attribute. So not everybody can edit or even view a value.
And don't forget the WTDocument assiociation (Configurable Link)
Christophe Schindler‌ don't forget to vote for your own idea!
olivierlp
Community Manager
Status changed to: Archived
