Add Cognos "Active Reports" support to Windchill
Active reports are not currently supported, but need to be supported.
Business Justification: Active Reports offer interactive behavior which would benefit critical executive level reporting.
Tests done:
1. In Cognos Connection, navigate to Public Folders > Windchill > <someFolder> and start Report Studio.
2. Select to create a new report from a template and select 'Active Report' as template.
3. I added a simple list of part name/numbers and saved the report.
4. In jconsole, call exposeReports() from the ReportingSystem monitoring MBean.
The result is '0' and there is no new report visible under Site > Reports in Windchill. A 'regular' Cognos report template is exposed fine and works as expected.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
