Add Default Trace Code as an editable attribute in the Edit Multiple Objects function
Currently "Default Trace Code" is the only attribute which does not appear in the Edit Attribute Value drop down on the Edit Multiple Objects function. All other attributes on partrs are available to edit on across multiple objects, meaning if a user wants to edit dozens or hundreds of parts but needs to change the value on "Default Trace Code", they'd have to do it one-by-one. A call was opened to PTC tech support, but resulted in R&D calling this "working as designed". Therefore, I am submitting this item as an enhancement request.
C13700159 _EditMultipleObjects_EditAttributeValue_DefaultTraceCodeMissing_ScreenShot1.pngC13700159 _EditMultipleObjects_EditAttributeValue_DefaultTraceCodeMissing_ScreenShot2.pngC13700159 - Default Trace Code attribute missing from Edit Attribute Value dropdown within the Edit Multiple Objects function
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=13700159
CS254900 - The "Edit Multiple Objects" UI does not allow to properly handle multi-valued attributes in Windchill PDMLink 10.2
https://www.ptc.com/en/support/article?n=CS254900&source=Case%20Viewer#_ga=2.96050644.97540600.1513799128-1937679740.1500921472
CS276380 - Is it possible to set Default Trace Code attribute from Edit Attribute Value dropdown within the Edit Multiple Objects function in WIndchill PDMLink
https://www.ptc.com/en/support/article?n=CS276380&source=Case%20Viewer#_ga=2.132266694.97540600.1513799128-1937679740.1500921472
1 Comment
dritter-3
FYI:
PTC provided a solution / workaround with our PTC Technical Support Case Part Master attribute "Default Trace Code" is missing in table "Edit Multiple Parts" but didn't update the PTC Article Is it possible to set Default Trace Code attribute from Edit Attribute Value dropdown within the Edit Multiple Objects function in WIndchill PDMLink
I don't know if this is a official solution or not. I asked PTC to update the Article.
