Add Effectivity and Modify Effectivity UIs are very less flexible for customization and have very few configuration options. Even basic requirements require OOTB JSP customization.
Here are few of them.
1. Effectivity context search page should allow limiting the search result to a particular Part Sub Type. Check the product Idea here.
2. System must prevent switching effectivity context on an effectivity record if the Part was already Released (states must be configurable) .
3. System must prevent changing the effectivity start date on a Released Part if that date is a past date.
If would be good if PTC can provide configurations or customization hooks at least, so that we can avoid OOTB JSP customization.
