As of Windchill 11, there is still no Level column in the Structure view.
This means that all BOMs exported from Windchill will be flat, with no assembly level indication.
For large/complex BOM's this renders the Windchill structure export function useless since it would be so time consuming to indent the BOM after export.
PTC please add this basic functionality to the Structure view functionality.
Reference:
Is it possible to show the BOM Level column on Part structure page in Windchill PDMLink
https://www.ptc.com/en/support/article?n=CS269478
Query Builder Report to get the bill of material (BOM) report for latest iteration of latest version in Windchill PDMLink
https://www.ptc.com/en/support/article?n=CS20698
To export the product structure with levels, use the Reports > Multilevel Reports. In the pop-up window, click on the table-looking icon all the way on the right side and select Manage Structure Views. Set up the columns you want and Ok. Then click Actions and export the file type you want.
