Add Purge representations functionality
4 Comments
rwesner
2-Guest
I clearly support this demand.
While waiting you could consider the functionality Windchill Benefit Bundle "Purge Representations" written by consultant
Dieter Hackl
b.yond information technologies e.U.
Hofweg 27
4209 Engerwitzdorf
Austria
Office: +43 (0) 720 306158
Mobil AT: +43 (0) 676 3636123
Mobil DE: +49 (0) 152 53387090
b.yond@byond.co
TomU
According to Steve Dertien, Technical VP, this can be done with a custom publish job:
  • Jobs do not have to exactly publish data, customers have created jobs to delete old representations.
  • For instance, remove all representations greater than 1 year old that are not on the latest version of the object and have no markups.
Taken from his presentation at PTC Live Global 2013 titled, “PTC 126: Advanced Visualization Implementation Techniques”
OliverDroop
There should be several configuration options based on which rules the representations should be wiped out:
All Non-Defaults
Name Pattern
Config Spec
All versions or only non latest
expluded states which should not be purged
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS62748
could be enhanced or made available via UI instead of console
PTCModerator
Emeritus
