Every once in a while I get caught in WQS Prediction with having parts that look like they are being calculated but actually have a "fixed" failure rate or MTBF due to the Failure Rate Type being "Specified". I would like to see an option to select the Text Color for Specified failure rate types. After a calculation, these parts would be easy to find, similar to the "Defaults used color option in the Prediction settings.
