ASME Y14.35 requires a Revision table for drawings. This information is commonly processed in Windchill. It would save a lot of time if this information could be exposed in a Windchill parameter that could then be used on drawings to automate the revision history table. Solidworks has this with EPDM:
https://razorleaf.com/2009/10/epdm-workflow-rev-block/
Similarly it is common practice to have a where used, used on and QTY on engineering drawings. This is information that Windchill has that could be passed to the drawing via a parameter.
These parameters should have the ability to have auto-updating turned on and off (like Microsoft Word fields) in order to satisfy configuration control over the drawing.
