There is no way how to add info in the form design (and reports) from more than one record in the system tree. But it's really needed in some cases for customers.
For example one of the customers needs to display some information about part and parent assembly (part name, part ID, parent assembly name, parent assembly ID). But there is no available separated fields for parent assembly info (exception is "Parent Assembly" field which returns parent assembly name. But what about Parrent ID ?)
Please add separated fields for parents assembly in the system tree table
