I believe it is fair to say that all Creo users learn to save frequently. If you save any change in your workspace which you don't want to check in then the only available solution (as best I can tell) is to delete the part from your workspace, then go find it in the commonspace (aka Windchill Cabinet) and put a new copy in your workspace. This is a time consuming PITA. We need a better solution.
