Add a "replacement" business link in Change Management
In Change Activities, we can track impacted datas (all changeable objects ... Parts, CAD, Docs ...) and resulting datas
For revised objects, it is easy to find the old / new object : they have the same number / master
but in case of replacement. We can't retrieve easily which part replace which one ...
It will be great to have the abilty to define a "replacement" link between objects that are defined in the old/new data fields of the change activity.
And may be able on that link, to set a context (Assembly , End Item...) where is done the replacement
And then being able to know :  this part is replaced by this one in that product, regading this change request
2 Comments
GregoryPERASSO
Seems to be released in 10.2  ?  with a "supersede" action in Change Activities and indicator on info page
PTCModerator
Emeritus
Status changed to: Archived
