In Change Activities, we can track impacted datas (all changeable objects ... Parts, CAD, Docs ...) and resulting datas
For revised objects, it is easy to find the old / new object : they have the same number / master
but in case of replacement. We can't retrieve easily which part replace which one ...
It will be great to have the abilty to define a "replacement" link between objects that are defined in the old/new data fields of the change activity.
And may be able on that link, to set a context (Assembly , End Item...) where is done the replacement
And then being able to know : this part is replaced by this one in that product, regading this change request
