Add a refresh or re-run search button
Often times when I perform a rename, move, or other change from the search window I find myself re-running the exact same search I have up because the search does not refresh automatically the data shown is out of date.
To re-run the search I typically click edit criteria, and search again. Sometimes I also have to scroll depending on my view and everything I have listed in the search. It would also be helpful if you think someone made a change after you ran your search.
I'd just like to see the refresh slapha_1-1585595959201.png button in the search toolbar, or some sort of link that is a one-click to re-run the search using the same criteria.
A similar idea to automatically update the search result after a change initiated in the search window was rejected as "No plans to implement": https://community.ptc.com/t5/Windchill-Ideas/Search-results-should-refresh-after-performing-a-revise...
