Looking for an ability to add Associated Process Objects and Associated Reference Objects on Change Tasks with configuration instead of customization.
We release at the Change Task level rather than the Change Notice level. It would be nice if we could activate with a setting the ability to show the associated process objects to be able to close out PR/Variances/etc. for small level changes.
I also think Associated Reference Objects as general references would be helpful, for example if a design was made from an existing design, it could be added as reference instead of pure affected depending on the use case.
Even for CTs as individual tasks, often you need to reference other documents but don't need them changed or flagged for change.
