There is no way I can find to export and import a table view from one classification node's search result to another classification node's search results. As a work-around, they can be created manually at each branch, but this can be tedious if you have a large classification or the need for multiple, different table views.
As we add more sub-types of parts, it would be nice to share common table views without creating and managing them all manually and individually.
