Add ability to import table view to specific branch of Classification search results
There is no way I can find to export and import a table view from one classification node's search result to another classification node's search results. As a work-around, they can be created manually at each branch, but this can be tedious if you have a large classification or the need for multiple, different table views.
As we add more sub-types of parts, it would be nice to share common table views without creating and managing them all manually and individually.
1 Comment
BartLefevere
6-Contributor
There is a loader for classification views:
<!DOCTYPE TableViewDescriptor SYSTEM "standard11_1.dtd">
<TableViewDescriptor>
<ObjectID><localId>com.ptc.core.htmlcomp.tableview.TableViewDescriptor:000001</localId></ObjectID>
<name>Nuts_1</name>
<tableID>wt.part.WTPart.defaultSearchView~DYNAMIC~WCTYPE|wt.part.WTPart|local.icarus.Article~IBA|SVC_CLASSIFICATION_1*NUTS</tableID>
(SVC_CLASSIFICATION_1 is the binding attribute, NUTS is the internal name of the classification node)
I have generated the loaders from Excel, for a classification structure of about 500 nodes. On each node I replaced the Default Part View, so the user does not have to select the view at each node.
