As currently exists for on Revise it would be very useful to allow the entering of a specific Revision on Create. this would allow us to enter a starting Rev other than the initial which is common for Sub Contractor or Buy sourced data where the intial Rev provided to us is not the first. We currently work around this by creating an initial Rev, Revising it and assigning the correct Rev value and then delete the initial Rev, pretty frustrating for an end user.
