Add ability to specify the default Change transition
Currently if custom change transitions are defined and the OOTB "Change" transition no longer makes sense to the business and is therefore not used, the default change process transition is blank in the implementation plan.  Per technical support the default change process transition is hard coded to "Change".  Please add the ability for administrators to set this.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
