The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add an architecture to connect to Azure Active Directory
Currently, Windchill can connect to a local Active Directory with fully documented procedures.  With emerging change from local AD to Azure AD within corporations, users should be able to have a properly tested and documented solution for this configuration.
We currently have a mix of AD and AAD connected principals, with Azure-connected principals getting their cloud-joined credentials (domain\user@company.com) auto populated, which is not the proper username that Apache/WindchillDS authenticate against.
