Security Alert Log4j Security Vulnerability. Click here to know more.
Add comment when import with SpreadSheet
When you import a Spreadsheet, you create an iteration but you can't add a comment to explain why you have done the iteration.
It should have the same process of check-out and check-in.
3 Comments
DavidBrand
I'm just starting to look at importing from spread sheet to add a "cost" attribute Parts and think this idea is a must.
I'm thinking that if we have an attribute for cost and export a BoM to Excel we can create a costed BoM.
There could be another attribute that captures if the cost is known or an estimate.
Is anyone else doing anything similar?
GaryWalling
3-Visitor
Comments should be mandatory for any programmatic iterations. I know that the user can do an iteration "difference", but having a comment gives background explaining why it was changed.
olivierlp
Community Manager
Status changed to: Archived
