Add connected change task in changes tab of object
In the changes tab of an object, you can see the connected change notice, not  the connected change task.
If there are several tasks connected to a change notice (more than 10) it takes to much time to find the right task.
Connected tasks should also be visible in the changes tab.
2 Comments
JeffZemsky
Bruno,
With the Change Summary table on the CN one can easily see all the data and which task they are on.  Here is an example showing the data available that I added via table view.  A user can quickly find, sort and filter with this table.
olivierlp
Community Manager
Status changed to: Archived
