When attributes are sent from Windchill WorkgroupManager to Creo Elements/Direct Drafting, they can be put onto the titleblock through text references.
There's no way to customize these text references in Drafting, before they are put onto the drawing.
This is commonly used to e.g. add a drawing scale onto the titleblock, because this isn't an attribute stored in the database.
So what should be done:
Call a customizable macro after loading the attributes in the logical table "WTtr", and before updating them in the drawing.
